Message 1 of 4
Halo 3+ query
I am on full fibre and a halo 3+ contract
For historical reasons I have 4 black disks which for the past year have worked perfectly
Today one of the disks lost it’s connection and one of the others was flashing blue
I was able to reset the disk that had lost its connection but when I attempted to reset the flashing blue it knocked out one of the others
I have attempted to do a reset several time but also with the same result
It makes me wonder if BT have now imposed a limit of 3 disks
Has anyone got any suggestions as to how I can get the 4 disks up and running again
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Halo 3+ query
As far as I am aware, Halo 3+ comes with Complete WiFi and according to the help pages, supports a maximum of 3 discs via a Smart Hub 2:
BT Help: Fix problems with Complete WiFi
Perhaps a firmware update or similar has finally kicked in the limit on your set up?
I can’t offer a suggestion for a fix personally, maybe time to look at whole home WiFi instead?
Message 3 of 4
Re: Halo 3+ query
I will have a look at your suggestions later
Anonymous
Not applicable
Message 4 of 4
Re: Halo 3+ query
Also don’t forget you have free home visits from “Home Tech Experts” with Halo 3+, so you can book one of them to take a look at your network and kit.
