Message 1 of 2
BT have sent me a EE Smart Hub WiFI Plus, and 3 BT discs (black) why?
Hi,
totally confused here!
Upgraded to Full Fibre 900 with BT Halo 3+ as they offered it at the same monthly charge when we had issues with our old BT HUB.
As part of the deal they said they would send out a SmartHub 2, three BT discs (black) and arrange for an engineer to set things up.
Anyway, kit arrived a day later than the engineer; however, the engineer issued and set up a SmartHub 2 as per original order shown in MyBT
I then receive a EE Smart WiFi Plus with three BT discs (black). I have no account with EE and so I can't use the app the suggest I use to set up the EE Smart WiFi Plus ...
Any ideas?
Should I just set up the three discs with the BT SmartHub 2?
Also, BT support weren't very helpful when I asked them!!
1 REPLY 1
Message 2 of 2
Re: BT have sent me a EE Smart Hub WiFI Plus, and 3 BT discs (black) why?
This must be a ‘benefit’ of paying the extra money for Halo 3+ on a 900 Meg connection.
The EE router is WiFi6 capable so will let you make most use of your higher broadband speed whereas the Smart Hub 2 is only WiFi 5.
So if I were you I’d switch over the router and you may be able to manage it through the BT app.
