Message 21 of 23
Re: BT hub2 beeps twice every hour
BT have solved it their end thanks for helpful suggestions
Message 22 of 23
Re: BT hub 2 beeping,
Hi @CarieCass.
Thank you for coming back and letting us know the engineer has fixed your issue.
Have a great weekend,
Katie 🙂
Message 23 of 23
BT have solved the issue their end no beeping now thank you for your help
