Message 11 of 23
Re: BT hub2 beeps twice every hour
I can't see how it can be the hub beeping, it doesn't have a speaker.
Message 12 of 23
Turn the hub off to see if you still hear the beeps.
Obviously if it has no power it can't beep so that will rule it out and you can try and track down what is beeping knowing it is not the hub.
Message 13 of 23
Thank you for that suggestion I will do that tomorrow morning ( I am an older person and at my best in a morning)
Anonymous
Not applicable
Message 14 of 23
Also don't rule out your smoke alarms.
With several you'll physically have to be really near to identify the culprit
Again do you have smart meter...they also have the capacity to beep.
Message 15 of 23
Smoke alarm is in another room & we don’t have a smart meter, I have stood next to the hub & it is definitely the hub, all very confusing
Message 16 of 23
Hi @CarieCass   So did you prove it by turning it off and then the beeping stops?
Message 17 of 23
As I said at the start, sounds like the battery backup unit.  Is it connected properly?
Message 18 of 23
BT hub 2 beeping,
Thank you to all who answered all sorted now by BT engineer
Message 19 of 23
BT have sorted it their end no beeping
Message 20 of 23
Beeping stopped bt engineer sorted it thanks for your help
