Message 1 of 2
BT sites greying out
My Win11 laptop has developed a problem accessing any BT sites, including this one.  Sites immediately 'grey out' on me  - i.e. the site comes up but it won't let me access it and the screen acquires a greyish appearance.  However no such problems with the Win10 PC, which I'm using atm.  Both systems connect via the same BT Smart Hub 2.  I mostly use Firefox on both systems but it's the same with Edge.
Any ideas?
1 REPLY 1
Message 2 of 2
Re: BT sites greying out
Yep, it's Malwarebytes browser guard add on mistakenly blocking cookie pop ups.
It did it a few weeks ago and then stopped but has restarted again recently.
