Message 1 of 8
BT smart hub 2 flashing purple
Hi,
I have recently moved house and informed BT. My activation date was yesterday and my BT box is still flashing purple.
I have checked all the connections, restarted the hub and restarted the modem and nothing appears to be working?
7 REPLIES 7
Message 2 of 8
Re: BT smart hub 2 flashing purple
if still nothing then phone CS 03301234150
Message 3 of 8
@Chlolouiseox I'm sorry your broadband isn't working. I presume you have full fibre if you have a white Openreach modem? If so what are the lights showing on that?
Neil
Anonymous
Not applicable
Message 4 of 8
Just to avoid any confusion around a white modem, do you have one of these & are the LEDs as shown?
Message 5 of 8
Hi,
yes I have that modem but the LAN LED isn’t showing?
Message 6 of 8
Yes, but are the PON and Power LEDs green and the LOS LED unlit?
Have you tried a different Ethernet cable between the ONT and Hub?
Message 7 of 8
Yes that’s correct they’re both lit up and the LAN is unlit.
I haven’t tried a different Ethernet cable because this one worked prior to moving, I moved house and now the box appears to just be flashing purple
Message 8 of 8
Is the hub configured for FTTP mode and the cable connected to LAN port 4?
