Message 1 of 2
Block Certain Devices
Hi all,
Just wondering if anybody knows how to block certain devices from temporarily connecting to the internet.
For example my children's  Xbox is 192.168.1.119 when I send them to bed they tend to turn on the Xbox and play while we are downstairs, however when we was on sky we could use a setting in the firewall to block any traffic from that particular IP.
Is there a way I can do the same and block the IP from accessing the internet
The Hub I have is a Smart Hub 2
Thanks in advance
1 REPLY 1
Message 2 of 2
Re: Block Certain Devices
Parental contrils is what you're looking to change, can restrict specific devices
https://www.bt.com/help/security/how-to-keep-your-family-safe-online-with-bt-parental-controls-an#se...
