Message 1 of 6
I would like to choice DHCP
At first, very sorry I'm bad at English.
I started to use new wifi, and I can connect it by other devices. But my laptop cannot connect.
Sometimes, the laptop connect several sec and then disconnect.
In setting menu, my laptop is "Address assignment: static". And other devices are not.
So I assumed this is bad point, however I cannot change this setting.
I changed about IP settings in my laptop (windows). But it doesn't change. So maybe it can change in BThub setting menu.
Please teach me about the setting.
Thanks.
5 REPLIES 5
Message 2 of 6
Re: I would like to choice DHCP
 please  check this menu.
Message 3 of 6
@apto117
Are you a BT Business Customer?
Message 4 of 6
Yes, maybe.
My company provided a home internet connection for me and others.
So I'm not sure about what is the network.
But the menu, shows me "BT business smart hub manager".
Message 5 of 6
And static IP status is off.
So I'm confused.
Message 6 of 6
Hi, @apto117 as you have BT Business broadband you'll need to post over on the BT Business Community as this one is for residential customers.
Neil
