Message 11 of 22
Re: Broadband dropping out
Yes I do have fibre broadband direct into the house and definitely not via green box.
Message 12 of 22
When my broadband is running correctly I am getting close to my advertised speed 74 Mbps.
When it drops out it is of course, nothing then when checking speed again it can be very low, it could take hours to get back upto full speed.
Message 13 of 22
please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
do you have digital voice or still normal connection for phone?
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 14 of 22
Thanks for reply and Info, have already done that a couple of times and sent info to BT.
Yes I have the latest hub and digital voice,  telephone system is a  nightmare compared to old copper wire analogue system.
Another engineer coming on Tuesday morning?
Message 15 of 22
stats may be helpful to the people trying to help you on the forum
Message 16 of 22
Well I have logged into router,  advanced,  technical log.
So far so good.
Followed link you gave me.
Entered my phone nnmber ? get message.   There is no available data for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided.
We have had this number for approx 40 years?
I exported both the Technical Log. Information and Event Log for today to Excel files ?
Message 17 of 22
You are on digital voice hence why the dslchecker will not work.
You can use the camera icon to upload a screen shot
Message 18 of 22
Message 19 of 22
@harrysta
You might want to review the amount of personal detail viewable in your screenshots
Message 20 of 22
I see from your screenshots that your 5GHz carrier is on channel 36, you might want to change that if you have Sky Q it will cause conflict
