Message 1 of 6
Broadband speed
Looking for some advice.. had FTTP installed for about 4 months and my speed to devices (all devices) has always been around the same. To the hub I receive 900+ mb as seen. Any guidance on how to improve the speed or what could be causing the huge drop?
5 REPLIES 5
Message 2 of 6
Re: Broadband speed
are your devices connected by ethernet cable 5E or better or are you using wifi?
Message 3 of 6
Re: Broadband speed
All via WiFi
Message 4 of 6
Re: Broadband speed
Speeds with WiFi are susceptible to interference from devices in your home so no speed guarantees  over WiFi.  Are you sure your devices are connecting to the faster 5ghz network not the 2.4ghz
Message 5 of 6
Re: Broadband speed
yeah all devices connected to 5ghz
Message 6 of 6
Re: Broadband speed
@TaylorD132
You are unlikely to get anything like the full speed over wireless, on a single device.
It was never intended that people get full speed on all devices, especially on a wireless connection. The intention is to allow that bandwidth to be shared among family members and multiple devices, without each user noticing any slowdown.
Here is a quote from old post by @SeanD  on 18/06/2021
"I think for the first time ever we are in a situation whereby the speed you can now get through Full Fibre outperforms the capabilities of many devices.
The Smart hub 2 does not come with Wi-Fi 6 but this is something we are looking to include in our next generation of Hub.  I don't have any info as to when we will launch a new router by Wi-Fi 6 will bring some improvement.
As an example of what I mean in terms of devices not being able to support the full breadth of speed available on Full Fibre , take a look at the table below.  This is just for a couple of Apple Smart Phones and Tablets along with  popular Samsung models,
Apple (Smartphones) Dualband (2.4 & 5Ghz) Theoretical Max speed on 2.4Ghz connection Theoretical Max speed on 5Ghz connection
IPHONE SE Yes 60mbps 300mbps
IPHONE SE 2020 Yes 135mbps
600mbps
Samsung (Smartphones) Dualband (2.4 & 5Ghz) Theoretical Max speed on 2.4Ghz connection Theoretical Max speed on 5Ghz connection
galaxy-s10e Yes 135mbps 600mbps
galaxy-s10-5g Yes 135mbps 600mbps
Apple (Tablets) Dualband (2.4 & 5Ghz) Theoretical Max speed on 2.4Ghz connection Theoretical Max speed on 5Ghz connection
IPAD pro 3rd gen (Nov 2018) Yes 135mbps 600mbps
IPAD pro 4th gen (March 2020) Yes 135mbps 600mbps
Samsung (Tablet) Dualband (2.4 & 5Ghz) Theoretical Max speed on 2.4Ghz connection Theoretical Max speed on 5Ghz connection
galaxy-tab-s5e Yes 100mbps 300mbps
galaxy-tab-s6 Yes 60mbps 600mbps
