Message 11 of 14
Re: Bt complete wifi black disc query Dual Band Support
Current discCurrent disc
Thanks here is my current disc supporting :-
on 5ghz  1 x 650  mbps 1 x 351 Mbps on 2.4 1 x65 and 1 x 78.
As you can see in the picture Manager says Dual band NO.
Message 12 of 14
That only reinforces my theory.
The hub doesn't know the capabilities of the disc, all it knows is that it can contact it on the 2.4GHz band but not the 5GHz one so it assumes that it is not dual band.
Message 13 of 14
why not use powerline connectors to connect from bedroom to router, do away with wifi altogether, this is ow my grandsons PS5 connects to the internet.
PS5 - cable - powerline box in power socket via mains wiring to powerline beside router - cable - router
Message 14 of 14
Thanks will look at various options.
