Message 1 of 4
Buying Hub 2 extra discs?
Hi all,
I have bt broadband with a Hub 2 router (no extra discs)
I currently have the wifi turned off on my hub2, and use a Tenda 3x cube mesh wifi. But it drops off so much - I wanted to try BTs own wifi discs.
I don’t want to upgrade to the halo package - I have no EE signal round my house, and you can only order “1 disc, then have to contact support to get an additional 2x discs”. I know I need 3 - as 3 Tenda cubes just about covers my house, (3x floors, 6 beds)
I looked on google - and see you can buy bt discs, but are they for an old set up?
id like to just buy a set of 3x bt discs that work with my Hub 2, where the hub also acts as a wifi repeater, as well as the 3 discs.
thanks for the help.
3 REPLIES 3
Message 2 of 4
Re: Buying Hub 2 extra discs?
Only the black 'Complete WiFi' discs form a mesh with the Smart Hub2. The white 'Whole Home ' discs  don't.
Message 3 of 4
Thank you for the fast reply!
Have BT locked their smarthub2 to only work with the discs from them???
I can see second-hand black complete wifi discs on eBay.
i would prefer to just buy a set of 3x new ones from BT, but it looks like they are actually hard to buy new.
thanks again.
Message 4 of 4
No, it's the reverse, the black discs only work with the SH2 as they form a WiFi mesh and don't require an Ethernet connection to the hub as the white discs do.
