Message 1 of 3
Can I Smart Hub 2 be used like a disc?
I know there are stacks of questions and explanations about repurposing a hub as an access point - either hard wired via network cable or utilising powerline etc.
Is it physically impossible (I.e. wrong tech on board) to repurpose one and use it just like a disc; I.e. plugged in elsewhere and repeating the signal as part of the mesh system?
I think it is but all roads seem to lead back to an historic forum answer which only covers access points. Thanks.
2 REPLIES 2
Message 2 of 3
Re: Can I Smart Hub 2 be used like a disc?
No, you can't do that, you can only repurpose it as a WAP
Message 3 of 3
Thank you. I thought as much but useful to finally put that idea to bed!
