Message 1 of 4
Can I keep my SSID and Password
Hi
Apologies if this has been asked but I couldn't find it, I'm new to the forum.
I'm about to get FTTP so my new EE router has arrived. When the engineer connects it all up next week can I change the fibre router settings to those of my old BT router (latest version) so I don't have to re-register dozens of smart devices?
If I can, is there an idiot guide so I don't mess it all up?!
TIA
3 REPLIES 3
Message 2 of 4
Re: Can I keep my SSID and Password
Yes.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 3 of 4
Log onto the BT Smarthub
Home (bthomehub.home)
and go to the Advance settings then click on wireless and change the SSiD and password to your previous details then click save.
Message 4 of 4
Thanks - I wasn't sure if the move from copper to fibre could be done so I best make a note of them soon!
