Message 1 of 1
Can I use hybrid connect with third party router and BT router as an access point?
Right now I have the ASUS DSL-AC88U router which is great. Apart from the fact it has terrible 2.4GHz wifi connection. So I'm planning on disabling it and using 2.4GHz with the BT router connected as a wireless access point.
I know that the hybrid connect cannot connect to the ASUS router. But can it connect and function when connecting to the BT router... which is connected to the ASUS router as a WAP?
My question is, will it just think the broadband is down since it isn't the main router thus activating the hybrid connect? or would it be able to tell the BT hub is getting a broadband connection from the ASUS router?
