Message 1 of 3
No Internet Access when connected to VPN
So I am connecting perfectly to my Hub, however it seems to encounter an issue when using OpenVPN. It comes up with:
This has really confused me as I had connected perfectly fine to my VPN before the router upgrade. I have tried many things including reinstalling the vpn, restarting and messing with a few settings in the hub admin panel. I'm still lost and I appreciate any help!
2 REPLIES 2
Message 2 of 3
Re: No Internet Access when connected to VPN
If all other devices on the network work normally and only the work PC has issues unless the VPN is connected, it’s very unlikely to be a BT broadband problem. It usually points to a DNS or network configuration issue on the computer, especially if the VPN changes routing or DNS settings.
Message 3 of 3
You are replying to a 4 year old thread!
