Message 1 of 3
Does the WiFi disc have to be left powered all the time.
My car struggles to connect to the home WiFi when parked outside.
I have wondered about getting a WiFi disc but would probably only switch on when needed, do they need to be left switched on all the time.
MB
PS If only the Home Hub had a socket for an external antenna then probably would not need an extender!
MB
2 REPLIES 2
Message 2 of 3
Re: Does the WiFi disc have to be left powered all the time.
Hi @JMB Thanks for posting your question, No the wifi disc doesn't need to be permanently left on.
Neil
Message 3 of 3
Thanks, I get good coverage around the house. I have one PC that tracks ships 24/7 and is on the other side of the house from my Home Hub so I have an external antenna on that PC.
My car's Sat Nav uses a horrible system where you connect to with a 'smart' phone and mark a new destination on its mapping. It struggles to connect to the Home Hub so I though that with a WiFi disc, I could just power up when I need to get a reliable connection to or from the car.
Will have a think about getting a WiFi Disc.
MB
