Message 31 of 43
Re: Can't connect my Nest Wifi Point
You don't need the home hub 2 in the network as you will have 2 routers unless you put the Google router in bridge mode
Unless you require Digital Voice, there is no need for the home hub.
Message 32 of 43
I know but this what they are telling me. So you said I can't do option 1. Option 2 I did but it didn't do anything and option 3 I don't know how I would so that
"When your set up is ONT Box > BT Smart Hub 2 > Google Nets wifi router. You have to  reach out to your internet service provider to let them know that you need some settings to be implemented to your modem to make it work properly with your Google Wifi. This is also what my Senior Specialist Team mentioned on the result of their investigation.
Option 1: Enable bridge mode on the modem and router combination/upstream router settings.
Option 2: Disable the firewall (or put it in the lowest available setting).
Option 3: Set a Demilitarized Zone (DMZ) on the modem and router combination/upstream router. Open a port for the Google Cloud service on the modem and router combination/upstream router using port number 5222 UDP.
Note: This will help our Google Nest router to have a smooth performance compare to connecting it directly to the main modem as having VLAN Tagging is not supported."
Message 33 of 43
@licquorice can you help with option 3? Or is it Google taking rubbish again. I suppose the only thing is it all worked before I got fiber.
Message 34 of 43
Let's get back to basics. Does everything work when the BT hub is not connected? I.e just Google devices connected directly to the ONT.
Message 35 of 43
No the nest point  (WiFi extender) doesn't work. The nest router does work and everything can connect such as smart speaker's etc
Message 36 of 43
In which case the problem is entirely with Google, there is no configuration changes you can make to the ONT, it is not accessible to the user. I'm not familiar with the Google devices so can't offer any advice there I'm afraid.
Message 37 of 43
Ok thanks.
What I dont understand is that it worked perfectly before I moved to Fibre.  The set up was home hub - nest router I had no issues.
Message 38 of 43
Have you tried factory resetting everything and starting again from scratch?
Message 39 of 43
Yup several times. In various set ups.
Message 40 of 43
I really can't see what is going on here. As far as the Google router to Wifi point is concerned, absolutely nothing has changed. The only change is that the Google router is now connecting directly to a modem rather than via another router and modem as before. I could perhaps understand it if the Google router wasn't working but not why it is just the wifi point.
I assume you are following the instructions here
If the following is my correct understanding, nothing has changed within the Google domain.
Previous setup  Line > Modem-router combined (hub) > Google router > wifi point
New setup Line > Modem > Google router > wifi point
