Message 11 of 43
Re: Can't connect my Nest Wifi Point
Ok thank you. Do you have any idea what it might be. ?
Message 12 of 43
@tommcdowallwrote:
Yes I can contact to various devices (phones, smart speakers etc)
Yeah I have factory reset it a few times, still the same issue.
Sorry to be clear. ONT to Google Nest Router provides internet connectivity?
BUT the Nest wifi point will not connect to the Nest Wifi network?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 13 of 43
Yes, the ONT to the Google Nest router provides internet connectivity.
Correct, the Nest wifi point will not connect to the Nest Wifi network.
Google has said it could be the ONT and I need a modem. Not  sure what the difference is.
Message 14 of 43
As previously stated, Google are clueless. The ONT is a modem and cannot be changed.
Sorry, I have no idea what the problem is, but Google are just giving you a load of nonsense.
Message 15 of 43
Given the Nest Router is happily connected to the BT network via the BT ONT, the problem has to be from the Nest Router onwards. Does the Nest wifi point have a QR code you have to scan to join Nest Wifi?
Message 16 of 43
Read here
There seems to be a problem with the IOS (Apple) app. Are you using the IOS app?
Message 17 of 43
Yes it has a QR code but that wasn't working to well so I used the code instead.
Message 18 of 43
No I am using a Google pixel 6 with Android 12
Message 19 of 43
Hi - had exactly same message after a factory reset (which itself was a mistake for me as broadband was down in village and I should've just left it alone to come back). Anyway, in case it's useful to you, I fixed my issue by also resetting each of my two wifi points ( pressing button underneath for 10 plus seconds till it went into reset). Then you have a fresh WiFi point that was much happier to pair with my factory reset router. So, if you've factory reset your router, also reset the nest wifi points.
Tags (1)
Message 20 of 43
Thanks. Jason but I've reset the point and the router several times and the problem still persist
