Message 1 of 5
Can't provide internet problem
I have changed the BT Smart Hub 2 to an ASUS RT-AX52 router.
Everything went fine with the set up. On my mobile I can see all connected devices, however I get an error message that this connection can't provide internet and suggests a WAN problem. There is no issue with the cable, I tried several.
Any idea what went wrong?
4 REPLIES 4
Message 2 of 5
Re: Can't provide internet problem
What broadband service do you have, full fibre or FTTC.
If FTTC, that device won't work as it is just a router and not a combined modem/router.
If FTTP, have you configured the PPPoE settings with the generic credentials of username [email protected] and password BT?
Message 3 of 5
I have Full Fiber
And yes, I have used the user name and password as you said.
Message 4 of 5
The WAN section of the settings on the Asus router should look similar to:
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 5 of 5
I have reset the router and done the set up again.
This time I was offered a firmware update.
Once that was done everything worked fine.
Thank you for the quick replies.
