Message 11 of 53
Re: Cannot connect to Netgear Wifi Router
Thank you. Yes, this is the openreach modem I have.
At the back of the Netgear Wifi Router, it has the ''internet'' port, so I have plugged in that one. Am I correct?
Message 12 of 53
Thank you. I tried the Netgear app, but at the set-up stage, it said no internet connection.
I also tried www.routerlogin.net, 192.168.1.0, 192.168.1.1 after I have plugged in the Netgear, it couldn't go to that page at all.
Message 13 of 53
Thank you. yes my typo mistake.
Yes, I have tried all www.routerlogin.net,192.168.1.0 or 192.168.1.1. Nothing works.
Message 14 of 53
Which lights on the router are currently on?
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Anonymous
Not applicable
Message 15 of 53
So it has no Internet connection, which should be automatic & the web login doesn't work. Two entirely different issues. So it's either broken or you're not following the instructions.
Again, factory reset it, make sure the ethernet cable from the ONT is firmly connected to the Internet port on the router so that it clicks home & try again. If you still can't reach the router's admin page you need to be talking to Netgear.
Message 16 of 53
For Netgear, all lights are on correctly after I have plugged into the ''internet'' port. Just still don't know why it say no internet connection. And the problem is, I cannot set it in the app and the routerlogin page. So I do not know how to change the set-up in anywhere.
Message 17 of 53
can you not access the router by entering 192.168.1.1 into address bar and then enter router admin password
Message 18 of 53
Unfortunately cannot.
After plugged in the netgear router, I went to 192.168.1.1, it did not display the page.
Message 19 of 53
Hi @3465TYP   How are you (not the modem) connected to the Netgear router?
Message 20 of 53
Until you can access the Router to configure it, you won't be able to get internet access.
To be absolutely clear, you don't even need to connect the Netgear to the modem to be able to access it, so can't possibly be a BT problem.
