Message 51 of 53
Re: Cannot connect to Netgear Wifi Router
Thank you everyone again.
Oh, so need to change to UK in the setting.
I think the digital voice come as a BT package, although I have never use it or connect it.
I have learnt a lot from here. Thank you everyone.
Message 52 of 53
If you wish to use Digital Voice, you HAVE to use the BT hub.
There are ways to also connect a second router in conjunction wit the hub, but that is more complicated
Message 53 of 53
@Anonymouswrote:
@3465TYP
Just  thought but I take it don't have Digital Voice?
Good question.
If so, there is another option for third party routers. That is discussed elsewhere in this community.
Digital Voice with BT Smart Hub 2 in bridge mode - BT Community
Even if they don't have it now, the issue probably will come up again some time. But that may required a different BT Hub.
All we know is that @3465TYP had a BT modem connect to BT Hub Router
That second box could be one of several thing, not all of them Digital Voice capable.
