Message 1 of 17
Cannot connect to wifi
Every time I try and connect an iPhone or my Mac I get this error message in the WiFi connection box it’s not even going to a website it’s literally a pop up when I connect to the wifi
The https button does nothing and I can’t connect
I have booster discs round the house and have reset everything more than once, BT seemed clueless and said I needed new discs which seems unlikely
can anyone help please
16 REPLIES 16
Message 2 of 17
Re: Cannot connect to wifi
BT have changed the hub address to HTTPS so have you tried deleting the existing hub wifi connection om iphone and then trying to search and reconnect using hub wifi password and see if that connects
Message 3 of 17
You only get that message when connecting to the hub manager, not when connecting to WiFi.
Message 4 of 17
I’m not trying to connect to the hub though it’s just the WiFi anywhere in the house and I have done forget connection and reconnected
it’s very weird
Message 5 of 17
That is a browser message, not a WiFi connection error.
Have you set your browser's homepage to the hub manager page?
Message 6 of 17
This is what I am saying it’s not popping up on a browser it’s literally when I click the WiFi connection from the list.  I am IT literate (honest) and this is why it is baffling me
Message 7 of 17
I have no idea what you are doing but that is an error message from a browser trying to connect to the hub manager.
Message 8 of 17
Any chance of somebody clearing the image, so the rest of us can see it?
Message 9 of 17
@WSH Should be visible now
Message 10 of 17
Nope.
