Message 11 of 17
Re: Cannot connect to wifi
@WSH try now
Message 12 of 17
Yes, that's done it.  Thanks.
Message 13 of 17
@Stewnorriss   Interesting.
I take it you've gone into the hub and checked that the Wi-Fi connection details have survived the firmware update?
Message 14 of 17
@WSH The OP must be successfully connecting to WiFi to be getting that error message.
Message 15 of 17
Yes, good point but I would have thought the fact that it goes straight to the hub suggests there is some sort of error with the setup.
Message 16 of 17
Exactly, but has nothing to do with not being able to connect to WiFi as the OP asserts.
@Stewnorriss you should be able to connect to the hub manager at the link below. If your browser complains about the certificate, just grant it an exception
https://192.168.1.254/
No idea why your browser is trying to connect to the hub manager though.
Anonymous
Not applicable
Message 17 of 17
safe to continue?
You have either been seeing the last page you browsed or you have set you home page as the hub manager
test this by
GET chrome from ios app store see if you get the same
Open the App Store, search for "Chrome," and tap "Get" to install.
I suspect under chrome you be able to browse as you set other browser to see the hub manager as you hompage
Yes, it is safe to proceed. The warning is just your browser being cautious because it doesn’t recognise the certificate. The self-signed certificate still encrypts your connection, so any information you enter—like your admin password or WiFi settings—remains private and secure.
How to proceed using your browser
To continue using your browser, here’s how to bypass the warning:
Safari:
  • select Show Details
  • select Visit this website
  • confirm by selecting Visit Website
