Message 1 of 16
Change phone point to ethernet
Hi, I wish to change my master Ethernet socket in my lounge to where I have just a phone point in the hall (closest to the incoming feed). Photos attached with the phone point showing unused Green/white; orange/green/white & white/blue/green (?). Is it just a straight swap of connecting orange/white/blue lines? Any advice greatly appreciated. Thanks
15 REPLIES 15
Message 2 of 16
Re: Change phone point to ethernet
@zacheria78
Welcome to this user forum for BT Retail phone and broadband customers.
Who provides your phone and broadband connection?
Message 3 of 16
I have no idea of what it is you wish to do. You talk about Ethernet sockets but then show pictures of phone sockets.
Message 4 of 16
Hi, it’s BT for both. The reason I’m making the change is to upgrade my BT I need to convert internal from copper to fibre and will be easier by changing my Ethernet location.
Message 5 of 16
Apologies, possibly my poor choice of words. Rather than just a phone connection want to make it and internet connection for my router as per the RJ45 box if that makes sense.
Message 6 of 16
It doesn't make any sense whatsoever.
An internet connection isn't RJ45.
Just describe exactly what you have now and exactly what you want to achieve.
Message 7 of 16
Sorry, my ignorance. Right I have an Openreach Mk3 VDSL master socket in the lounge which I connect the router broadband to. I want to move my router to the hall and be able to plug in broadband there however there is currently only a phone point there. Do I just swap the boxes over and replicate wiring? Hope that make sense this time sorry.
Message 8 of 16
Right, that makes much more sense. There is no Ethernet or RJ45 involved.
Simply move the 2 wires that are currently connected to terminals 2&5 of the faceplate of the master socket to the data extension terminals at the rear of the socket.
You can then either just use a filter to convert your existing extension phone socket to RJ11 for the router to plug into or change the faceplate to an RJ11 faceplate so that the router can plug in directly.
Message 9 of 16
Hmm, looking closer at your pictures, I suspect at some point the socket in the hall was the master and the incoming wires have been crimped through to the socket in the lounge to make that the master instead. There also seems to be wiring for another extension socket.
What is the end result you wish to achieve?
Just one socket in the hall for broadband and nothing else or do you want telephone sockets at various locations as well?
Anonymous
Not applicable
Message 10 of 16
You have also mentioned fibre, albeit again in a way that makes no sense. Are you upgrading to FTTP? If so you can forget all about telephone sockets as they won't be used.
