Message 1 of 3
Complete WiFi via Ethernet
I'm looking for some info on a new setup in a new build house. I have the option to have some ethernet ports to be setup around the house, but wanted to know if they're worth getting for the black discs. I have a homehub 2and the disc that comes with it. Can the disc be used while connected to ethernet? I was thinking of having a single ethernet port installed upstairs and having the disc provide WiFi up there from that. Is that possible?
Thanks!
2 REPLIES 2
Message 2 of 3
Re: Complete WiFi via Ethernet
Yes, but use an inexpensive gigabit switch between the hub and the rest of your ethernet.
Cheers
Ted
Message 3 of 3
I'll probably have a switch for the cable into the upstairs. It was more a question whether the discs are able to broadcast WiFi from the ethernet cable. I know some of the discs and some can't.
