Message 1 of 4
Complete Wifi v whole home wifi
I have a 3 white disk whole home wifi to get a signal in my garden office. I have now received a black disk complete WifI with my upgraded subscription. I know the systems are not compatible. Should I abandon the 3 disk set and just use the new disk and is it likely to send a signal to my garden office?
3 REPLIES 3
Message 2 of 4
Re: Complete Wifi v whole home wifi
If your current setup is working, why change it?
Without trying it, it is impossible to tell if the black disc will work any better.
Message 3 of 4
thank you for your. reply. Yes the 3-disk home wifi works well, but would be much tidier to just have one disk. I guess I will have to try it.
Message 4 of 4
Its the only way you will find out.
