Message 1 of 4
Mixing Complete wifi discs with whole home wifi discs
Good morning,
I am technically challenged so please be gentle with me.
I have a BT SH2 and 3 complete wifi discs around the house, due to internal block walls.  They provide sufficient cover in the house.
I have a shed in the garden on to which I fitted a CCTV camera to observe the back of the house.  The camera is not connecting to the hub or any of the discs so I cannot monitor it.
I rearranged (on a temporary basis) the black discs, placing one in the shed and the camera worked.
I have a couple of questions;
  1. If I bought another complete wifi black disc from an online market place (trying to do it on a budget) will it easily integrate into the current system?
  2. If I bought a set of 3 white whole home wifi discs from an online market place will they integrate into the current system?
  3. As 2 above but if I hard wire 1 of them into the hub and daisy chain them to the shed will they work independently from the complete disc setup and give me the connection to the camera that I need?
Thank you for your time and knowledge.
3 REPLIES 3
Message 2 of 4
Re: Mixing Complete wifi discs with whole home wifi discs
I'd try option 1 first 🙂
Message 3 of 4
Thank you Steve,
I'm negotiating buying a disc but the seller does not know if it is a complete or whole home disc.
Are the complete discs always black and the whole home, white?
Message 4 of 4
Yes correct 🙂
