Message 1 of 20
Connecting my own Router to a standalone Smart Hub 2 (Fibre 2 Contract)
I have just moved into a new flat and I got the BT Fibre 2 contract which gives me a Smart Hub 2 which just plugs onto a phone socket and all my WiFi works through that. However, I have my own router (TP-Link Archer AX5400) which I want to use as the main source of WiFi instead of the Smart Hub. Main reason being is I think its a stronger router compared to the Smart Hub.
Is tthere any way I can do this? I've been looking at other forums but most of them are setting up a new modem and router, not just a router. Any help would be greatly appreciated,
Thank you 🙂
19 REPLIES 19
Message 2 of 20
Re: Connecting my own Router to a standalone Smart Hub 2 (Fibre 2 Contract)
Repurposing a router as a wireless point explained here… https://www.avforums.com/threads/faq-using-two-routers-together-extending-wi-fi.1554662/
Message 3 of 20
@DylanLP
I have Digital Voice so have to use the SH2 as the first connection point. From there i use my Asus DSL-AC68U to do everything else as a full router not an access point.
It's quite simple really.
Essentially what I've done is as follows:-
Set the SH2 to 192.168.2.1 with a subnet mask of 255.255.252.0 , disabled wifi, firewall , DHCP and port forwarded everything to my Asus on 192.168.1.1.
On the Asus being that it's a modem/router I configured port 4 as it's WAN port connected to the SH2 with it's wan port as a static ip address of 192.168.2.2 and default gateway of 192.168.2.1/subnet as the SH2.
For IPV6 in the SH2 I set the pinhole to point everything to my Asus .
Hope that helps
Message 4 of 20
Hey thank you for the reply, reading this I'm getting confused but I'll give it a try and hopefully figure it out! 🤣
Message 5 of 20
Whith all the IP addresses how do I change these settings? Also how do I tell the sh2 to point everything to my tp link router?
Thank you
Message 6 of 20
@DylanLP
You port forward all incoming traffic in 2 areas:-
IPv4:-
iPV6
The other thing I forgot to mention is some Firewall settings
Obviously within the SH2 I've set my Asus to use 192.168.2.2 always as in:-
Does that clarify things a bit?
I'll always try to help on this so any questions just ask.
Message 7 of 20
Will that method work with my Asus router?
Message 8 of 20
Yes, it's generic
Message 9 of 20
Cheers for reply.
So that's a work around that sorts my argument out with BT?
Message 10 of 20
My router BTW is an Asus 86U running Merlin software.
Cheers
