Message 1 of 4
Control WiFi Access issues
Hello
Is it just me having issues with this?
Basically, I set up a group, configure the days and times etc.. hit save.
Check the settings the following day and all have been reset to blank.
This is really frustrating.
3 REPLIES 3
Message 2 of 4
Re: Control WiFi Access issues
Hi @Flashingblade1 and welcome to our community.
Thanks for posting about setting the WiFi access controls, sorry you're having a few problems. Can you post some screen shots of what you're seeing?
Cheers
David
Message 3 of 4
Hi David, so as it stands at the moment, I've set the WiFi to pause on two devices on my network for the times above. What happens is that the configuration only saves for a day or two.. then disappears so the devices are back to having full access to WiFi overnight. I'm having to check every single day to make sure the restrictions are still in place.
Hope this makes sense
Message 4 of 4
Thanks for the reply @Flashingblade1 .
I can see what your trying to achieve. I'm not sure why it resets after a couple of days but I'd like to take a closer look to check if there's anything we can do to help. I'll drop you over a private message now so you can get in touch.
Cheers
David
