Message 1 of 2
Data limits on Hybrid hub
BT by their own admission have messed up a move for me. As a result I will be without my Broadband line for a week before they install a fibre line. In the meantime BT have sent me a Hybrid Connect box which I have got working. I realise this box runs off the EE mobile network. My overall Broadband plan has unlimited data so what I'd like to know is am I on unlimited data as well while I'm using the Hybrid box?
1 REPLY 1
Message 2 of 2
Re: Data limits on Hybrid hub
Hello,
'In package' the Hybrid Connect offers unlimited broadband, yes - but has a 30Mbps download limit on the bandwidth. Just so you don't go nuts I guess…? But when my landline has been down and the Hybrid Connect has kicked in, even with only 2 out of 3 bars lit, I get the full 30Mbps download and never have any capacity issues — upload is depleted too though so it all depends what you do with it, but should be sufficient.
But yes, should be unlimited.
