Message 1 of 5
Dynamic DNS issue with NOIP.com and SmartHub 2
I've used NOIP.com's DDNS service with my SmartHub 2 for some years now.  At some point it has stopped handling changes of external IP address.  If I power cycle the SmartHub, it comes up with a new IP address (of course, because I don't have a static IP), and my DDNS name resolves correctly to the new address.  This shows that (a) my credentials stored in the SmartHub are correct; (b) the SmartHub can negotiate correctly with noip.com.
However, BT keep assigning me new IP addresses.  When the address changes, the address that my DDNS name resolves to does not change.
Also, clicking the Refresh button on the SmartHub's DDNS page does not cause the address to update - and it doesn't even put an entry in the event log.
Anyone know what's wrong?  Is this a result of a SmartHub firmware update?
Tags (1)
4 REPLIES 4
Message 2 of 5
Re: Dynamic DNS issue with NOIP.com and SmartHub 2
This may be a NOIP.com issue, here's a recent link to a similar issue affecting Asus Router users
EXTERNAL LINK
* https://www.snbforums.com/threads/ax6000-not-updating-ddns-after-wan-ip-change.86016/ *
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 5
Thanks, but although the symptoms look identical, I can't see any such setting in the SH2.
I notice this morning that my external IP address has changed, and DDNS already points to the new address without any intervention from me, so either the problem is intermittent or it has gone away.  We'll see.
Message 4 of 5
There have been a couple of changes of external IP address since my original posting, and DDNS still appears to work, so I'll have to assume that the probem was temporary.
Message 5 of 5
Thanks for the update @DavidH7 . It sounds like this has sorted itself out. Post back if there are any problems.
Cheers
David
