Message 1 of 7
iPhone not connecting to Wi-Fi
Hi all,
my iPhone won’t connect to my home Wi-Fi.
we have 5 phones, iPad and multiple other devices connected in the house but only this phone has the issue.
I did contact Apple first but they said it is a ISP issue, contacted BT and they say it’s the device.
tried googling an followed all the recommended actions without success.
so, over to this community with crossed fingers.
6 REPLIES 6
Message 2 of 7
Re: iPhone not connecting to Wi-Fi
@Spewy87
Try a factory reset of the home hub,
https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Its possible that the home hub has run out of internal connections, a very common issue if you have devices that are using random MAC addresses. You can probably see lots of "unknown device" entries in the home hub connections list.
A factory reset clears this list, but eventually it will happen again unless you avoid using MAC randomisation (Private Addressing ) on your home wireless connection.
This is mainly a problem with Apple devices and later Android versions.
Message 3 of 7
Thanks, I followed the link provided, then the instructions to reset smart hub 2.
it tells you to press and hold the factory reset button fir 5 seconds but when I do that the hub doesn’t reset, nothing at all happens 🤷
Message 4 of 7
You need to press it for about 20 seconds until the lights flash.
Message 5 of 7
Unfortunately that hasn’t worked either
Message 6 of 7
Sorted now, it was a VPN issue
Message 7 of 7
Thanks for the update @Spewy87 .
We appreciate you taking time to let us know this is sorted.
Cheers
David
