Message 1 of 12
EE vs BT
Hi there im looking to get broadband to my house as im on 4g at the moment, but im getting confused as with BT it says my speed will be 2-6 mbps and 2mbps guarantee, but with EE it says i can get fibre 67 and the guaratee is 59mbps and same with Vodafone but a higher guarantee just wondering how this is as   thought they all used same network and im confused if i will be getting those speeds.
Thank you.
11 REPLIES 11
Message 2 of 12
Re: EE vs BT
can you enter your address and post results including the notes  this will show what is available to you and forum can help further
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
Message 3 of 12
Re: EE vs BT
Message 4 of 12
Re: EE vs BT
That shows you can get FTTC but speed only 6/2mb as you must be a very long way from your street cabinet. There is no FTTP available
Message 5 of 12
Re: EE vs BT
Ah ok so with EE and Vodafone they said the guarantee speed would be around 50mbps so would that not be possible
Message 6 of 12
Re: EE vs BT
Not if using the openreach network. Do you know if any neighbours have broadband on openreach network and if so what sort of connection speed do they get.   It may be that there is a problem with your address - it would not be the first time
Message 7 of 12
Re: EE vs BT
To check what your line can support log onto your  BT Hub  using this link and go to Advance settings the Technical log. On the Information page copy and post the Data Rate and Maximum Data rate.
If it shows the maximum data rate above 50Mbps then EE and Vodaphone are correct, it it shows lower than that then they being economical with the truth.
Message 8 of 12
Re: EE vs BT
If it was a issue with the address how would I go about fixing it or getting it fixed and I’ve looked at business WiFi and virgin says it can come to my location but it’s giving me speeds of 400 and up but it is fttc so would they still be the speeds I’ll be getting
thank you for the help so far
Message 9 of 12
Re: EE vs BT
Have you done the check that I suggested. If you have and it confirms what the BT Wholesale checkers shows then the only way to fix a FTTC connection would be to move house nearer the cabinet or get FTTP.
If you go with Virgin they supply their product through their own lines and will give you the speeds that they say they can deliver.
Message 10 of 12
Re: EE vs BT
Yes checked and seems everyone has the same speeds 6/2 around that so if I go with virgin I should get the speeds they say and it won’t be the same line bt and ee uses
