Message 11 of 12
Re: EE vs BT
@Bobbijack633 wrote:
If I go with virgin I should get the speeds they say and it won’t be the same line bt and ee uses
That is correct.
Message 12 of 12
Re: EE vs BT
Thank you very much for the help
