Message 1 of 6
Echo dot connection
Hey folks im trying to connect echo dot 2nd gen to bt smart hub ive tried lots of things but still no joy any help appreciated
5 REPLIES 5
Message 2 of 6
Re: Echo dot connection
@Bluecoopy
How far do you get with the connection process & what messages do you get?
Message 3 of 6
Not far at all i see the device in wifi but as soon as try to connect just wont at all then i get the message this device is updating then orange light on echo but its not even connected to wifi as says offline
Message 4 of 6
@Bluecoopy
Sorry for the delay in replying, I've only just seen your reply.
I assume that by now you've got it connected.
Message 5 of 6
Na gave up managed one time to get it going but not anymore
Message 6 of 6
@Bluecoopy
That's a pity.
Recently I've had problems with several of our Echo devices going offline & having to reconnect them.
I assume that when you tried you were near the router with Bluetooth activated.
Eventually I had to reset the Echo Flexes & Dots by pressing the activation button for around 30 seconds.
The first message after about 10 seconds says "Now in setup mode" but ignore that & keep the button pressed until you get the "Resetting your device, this will take about a minute" then release the button & wait till you get the message saying that your Dot has been reset.
Then start the process from scratch.
I had to do this a couple of times with each device.
