Message 1 of 4
Ethernet connection to pc needed ?
Do I need an ethernet cable for the internet ? I have a BT Smart Hub 2 router and pc.
Thanks.
3 REPLIES 3
Message 2 of 4
Re: Ethernet connection to pc needed ?
You will if your pc doesn't have WiFi
Message 3 of 4
Thanks Nigel
I've gone in to Device Manager and in the Network adapters, found Realtek 8812AE Wireless Lan.
Is this sufficient ?
Thanks again.
Message 4 of 4
