Message 1 of 6
Extender Discs
Would it be possible to use 2x AC 2600
add-on discs bought separately?
5 REPLIES 5
Message 2 of 6
Re: Extender Discs
Hi @DancingOlga welcome to the community and thanks for posting, are you looking to add two further discs to your current whole home wifi set up?
Neil
Message 3 of 6
Re: Extender Discs
I have purchased 2 separate add on discs, 1 6 months ago and now another  & wanted to know if they will work together if I connect one to my router by Ethernet!!
Message 4 of 6
Re: Extender Discs
@DancingOlga Yes, as long as they're the same model of disc they should work. If they're preowned I'd recommend doing a factory reset first then use the whole home wifi app to set them up.
Neil
Message 5 of 6
Re: Extender Discs
Thank you , that’s very helpful 👍👍
Message 6 of 6
Re: Extender Discs
@DancingOlga No problem, post back and let us know how you get on.
