Message 1 of 3
Extending cable from hub to router
I want to resite my router which would require about 18 metres of cable. Question is, what spec or category cable do I require. Am on FTTP with a smart hub 2. Is the cable for WAN just an ethernet cable with higher spec or what. Grateful for any help.
2 REPLIES 2
Message 2 of 3
Re: Extending cable from hub to router
You don't need anything special, good old Cat5E Ethernet cable is more than sufficient.
Message 3 of 3
Many thanks for that. Confirms what I suspected but nice to have an expert's opinion.
