Message 1 of 7
Black disc
Hello all,
I have recently built a garden office quite a distance from my house.  I got my electrician to run a ethernet cable to it and he's done so, and put an ethernet socket inside the cabin.
Can I plug one of my black BT wifi extender discs into this socket (and the power obviously) and it will work?
Sorry, probably a bit of a dumb question, but i'm only used to using these discs on wifi.  But as my garden office is so far from my house i think it is going to need to be kept plugged in with the ethernet cable.
Thanks.
6 REPLIES 6
Message 2 of 7
Re: Black disc
Yes, it should work.
Message 3 of 7
Re: Black disc
I don't use these disc so I may well be wrong but I thought you only connected the BT Complete wifi disc via Ethernet in order to set it up then you disconnected the Ethernet to get the disc to re-transmit/boost the wireless signal from the Smarthub.
I don't think it is able to be used while still connected by Ethernet cable to the Smarthub.
You could buy a Wireless Access Point and plug that into your Ethernet in your office and this would give you a wireless signal in the office and most WAP's also have an Ethernet connection so that if you have a device that does not have wireless it can still be used.
Message 4 of 7
Re: Black disc
Thanks.
Are there any affordable ones out there?
I thought this sort of thing would be tens of £ not hundreds of £!
Message 5 of 7
Re: Black disc
https://www.tp-link.com/uk/home-networking/access-point/tl-wa901nd/
Under £30.
Or TP-Link TL-WA901N 450 Mbps Wireless N Access Point, Passive PoE Power Injector, 10/100M Ethernet Port
On Amazon  £19.99.
Message 6 of 7
Re: Black disc
All you need is a cheap wireless access point or even cheaper, just re-purpose an old router.
Depending on what sort of speeds you are looking for and whether dual or single band, a couple of devices to consider are the TP Link TL-WA901N at about £20 or the TL-WA1201  at about £40
Message 7 of 7
Re: Black disc
Hi @gg30340   Complete WiFi Discs work perfectly connected by Ethernet and are ideal for an extended network. Obviously you need a SH2. I have one of my Complete WiFi Discs connected by Ethernet. Job done and no messing about with multiple SSIDs. Extra discs are loaned free if you subscribe to Complete WiFi.
