Message 1 of 3
Faulty BBU?
Problem: can't get my printer to connect to network.
Speed test done all ok
Openreach BBU has all three lights on (power, fault, charging)
Main unit has Power, PON, Port 1 lights on
Everything switched off & rebooted numerous times...printer still not connecting
Help please
2 REPLIES 2
Message 2 of 3
Re: Faulty BBU?
Early generation ONT’s have a BBU ( battery backup unit ) for the short lived phone port on the ONT , it’s of no use , and isn’t the cause of you not being able to connect your printer ….if you would prefer the fault light on the BBU to not be lit , you could replace the rechargeable batteries , most though simply remove the power lead from the BBU and plug it directly into the ONT , basically removing the unnecessary BBU from the system
Message 3 of 3
Re: Faulty BBU?
THanks for the suggestion, and now have it sorted!
