Message 1 of 6
Fibre not working
So, we pay for the full fibre which was working fine until a week ago when we had a different company (cannot remember the name) come down the street to fit “fibre optic cables” which were already here but now we have already had a BT technician out and they have said that the other company have cut the cables so they will need to be replaced.
A few days ago we were told they had been replaced but they have not been properly connected (which i can’t quite figure out why you would lay cable and not connect it but that’s fine I guess) so we have been told they would need to come out and connect them. Fair enough right?
We are now three days later and they still haven’t done anything to it at all and are constantly telling us that they will show up “tomorrow” which they never do.
We are now 10 days without our full Wi-Fi speed.
The picture above is our Wi-Fi on the “full speed fibre” package
5 REPLIES 5
Message 2 of 6
Re: Fibre not working
If the fibre cable was cut by another company it is up to them and Openreach to restore the connection. I suggest that you contact the offending company and complain to them.
You should however try connecting to your BT Smarthub by an Ethernet cable and run a speed test to establish if there is actually a problem with the connection or if the problem is a wireless problem which will have nothing to do with the cable being cut.
Message 3 of 6
Just tested via Ethernet and it’s barely any faster
Message 4 of 6
if you have FTTP - fibre to the home - what lights are shown on openreach modem ONT - and colour?
Message 5 of 6
If BT or Openreach have already sent out an engineer as a result of you having reported the fault, it would suggest that they are accepting that they will affect the repair.
You should call BT 0800.800.150 and report that there is still a serious problem.
If you still get no joy from them post back to see what further can be done.
Message 6 of 6
We have been told that an OpenReach engineer is coming out tomorrow so we’ll see what happens I’ll keep you posted
