Message 11 of 12
Re: Frustration trying to connect Smart Plugs to Smart Hub 2
@driverabc
Just to say that you can Edit a post rather that post another as a correction.
Message 12 of 12
It’s also worth noting that some (Usually the Square models) Teckin switches need the following enabled to be able to connect them up…
  • WPA2-PSK
  • AES
