Message 1 of 5
Genuine BT caller?
Just took a call from a local number in Wellingborough Northamptonshire. 01933 276075. Male claimed to be checking on slow internet speeds on our line and would call back at 15.00 hours today.
Is this number a genuine BT engineers number? Called the Operator on 100 who was worse than useless and suggested I call Directory Enquiries at some extortionate charge.
Can anyone help please?
4 REPLIES 4
Message 2 of 5
Re: Genuine BT caller?
BT neither does this sort of check nor does it ring a customer purporting to do so. Scam. Ignore the call back or, better still, add the number to your personal blacklist.
Message 3 of 5
Generally ISP’s don’t make unsolicited calls saying they are concerned about someone’s Internet performance, so if you haven’t complained, it’s likely the call is of a nefarious nature.
Scammers ‘spoof’ the phone number they seem to be calling from , the call probably wasn’t originated in Wellingborough
Message 4 of 5
It is a scam.
BT or Openreach will never cold call you to tell you there is a problem with your line, broadband or anything else. If you get such a call just hang up.
BT Scams | What you need to know to stay safe | BT Help | BT Help
Message 5 of 5
A simple rule.
Regard ALL unsolicited calls as a scam. If there is any slight possibility it is genuine, call back on a publicly published number for the purported caller.
