Message 1 of 9
Router connection
I have installed a replacement router.  I have internet access but it says limited access. When I access some sites I get a message unable to locate domain name servers.
8 REPLIES 8
Message 2 of 9
Re: Router connection
is the replacement a new BT hub/router or a 3rd party device
are you on FTTC or FTTP?
Message 3 of 9
What DNS servers did you enter on the new router?
Message 4 of 9
I didn't enter one.  I just selected my router by the SSID and entered the Wifi password.  Then connected to 192,168,1,254  and entered the Admin password,  I looked at what it has and it has 81.139,56,100 as primary and 81.139.57.100 as secondary.
Message 5 of 9
It is a BT home hub, exactly like I had before.  It supports digital phone.  Both handsets are working.
Message 6 of 9
I am on Fibre to Premises
Message 7 of 9
Make sure the hub is set for fttp working.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 8 of 9
Yes. FTTP is on.  Could this be a Windows problem?
Message 9 of 9
Under properties for the Wifi Connection under Advanced there is a setting for "Enable Federal Processing Standards for this connection" which is not checked.
