Message 1 of 7
Getting rid of Hybrid Connect from Hub Home page
I was fed up with paying £75 a month for my BB on Halo 3+ so I have just downgraded it to Fibre 2 at £31.99.
Same speed as before & I still have Norton Security.
Obviousy I had to send back the Hybrid connect modem and Wifi Disc both of which are not really needed as Hybrid Connect has come on for less than a couple of hours in the last 3 years and my devices connect straight to the hub fine and in fact many are hard wired via ethernet anyway.
On the upside it shows how reliable the Broadband is.
I have removed Hybrid Connect and the wifi disc from the My devices list using the advanced menu but I still have Hybrid Connect Shwoing as modem disconnected on the hub home page in bright orange.
How can I get rid of this?
6 REPLIES 6
Message 2 of 7
Re: Getting rid of Hybrid Connect from Hub Home page
Try a factory reset of the hub. Press the recessed button for about 20 seconds until the lights flash.
Message 3 of 7
Cheers.
I considered that but was reluctant to do so in case it wiped out any updates that have been done on the hub.
Message 4 of 7
It won't
Message 5 of 7
Any BT updates to the hub overwrites the software that it is updating and it becomes the "new factory reset" software.
Message 6 of 7
OK thanks.
So If I do the factory reset then restore the hub settings from a backup will that also reinstate any port forwarding settings?
Message 7 of 7
Yes, it should do, but it may or may not also restore the settings you are trying to get rid of.
Any port forwarding settings should only take a couple of minutes to recreate anyway.
