Message 1 of 4
HH6 5GHz very slow but 2GHz fine
I've recently noticed a problem with my 5GHz Wi-Fi connection so did a speed test to check.
5GHz
Download - 13.1 Upload - 13.0
Ping 973  Jitter Low 32 High 2506 on Download
Ping 444 Jitter Low 34 High 1202 on Upload
2GHz
Download - 70 Upload - 18.7
Ping 123 Jitter Low 55 High 237 - Download
Ping 265 Jitter Low 83 High 1338 - Upload
Clearly something wrong using the 5GHz network. Can anyone help sort this as I've never had an issue before?
3 REPLIES 3
Message 2 of 4
Re: HH6 5GHz very slow but 2GHz fine
Can anyone help please?
Message 3 of 4
Have you tried restarting hub to we if that helps?
Have you tried changing the wireless channel  best using WiFi analyser to find best available channel
Remember that the 5ghz network is faster but does not cover same distance from hub as the 2.4ghz
Message 4 of 4
I haven't restarted the router as yet. In fact having looked at the last reboot of just over a day I'm wondering if that's where the issue started. The 5GHz network has been fine for years.
Haven't tried WiFi Analyser but will do so.
