Message 11 of 13
Re: Harmony Hub & Smart Hub 2
Thanks. Haven't done that. It won't lose my activities will it as I'll be left with a brick. I'll have a think. But thanks
Message 12 of 13
Yes, it will wipe everything, which is the whole point. You will need to set it up again afterwards.
Message 13 of 13
  • @licquorice @Thank you so much. That power on while reset fixed it and the hub connected to the SH2. I had to restore everything but everything fine now.
