Message 1 of 6
Smart hub event log query
hello
I'm  trying to understand some of my events log on my smart hub. a little concerned as its also showing wifi connection from a device we don't recognise
can anyone advise?
many thanks
5 REPLIES 5
Message 2 of 6
Re: Smart hub event log query
@jukkate
You haven't got an iPhone that's using Private Addressing for your wifi connection by any chance?
Message 3 of 6
Android phones also use private addressing these days
The only way to prove it is to go through all your devices and make sure they are using their real MAC address and then see if those messages stop, I suspect that they will.
Message 4 of 6
Hi
Thanks for your reply
Yes i am on the laptop- but that laptop and our other wifi connections are showing with their MAC address. we were out at the time of this log and using another router, so i am a bit confused by it tbh
Message 5 of 6
just to clarify - whilst using a private connection, all our devices MAC addresses do show up later on in the day when we were in. at the time of the events logged we were out in a different part of the country and using a different router
thanks
Message 6 of 6
I suspect that 'Redside'  indicates that it is a device connecting to your BT WiFi signal rather than your home network.
