Message 11 of 14
Re: Has any one used a DrayTec 2865Vac on VOIP Via BT ISP
@sub101uk why do you keep talking about a Hub6? You have been told repeatedly that a Smart Hub2 is required for DV. The Hub6 is not the same device as a Smart Hub 2.
Message 12 of 14
Many thanks for your reply and confirming its a straight forward job to add external aerials . Yes someone did add external aerials to HUB 5 . From what I can see I just have to add some bulk head F connectors to the case of Hub 6 . Have you see the rear of the PCB on Hub 6 . You have what seems to be 2 outputs on 2.6 Ghz and the other 5 Ghz .
Message 13 of 14
I give up!!!!!!
Message 14 of 14
This has got to be a wind-up.
